Is the fuel dripping from your bowl vents??
If so, excessive fuel pressure (above 6 psi) is the mortal enemy of Holley's bowl float needle valves. They will lift and dump the further north of 6psi you get. Make sure your floats aren't set too high also.
Too many toys?? never!
