Ted, If you take your back left tire off you can see the left side of the roll bar. There is a rivet holding the two pieces of tubing together. What you have to do is drill out the rivet and drill on thru the other side of the tubing. Then you tap out the hole and install a bolt. I was not sure of the size bolt to use and the length needed. Mark
