Old 10-05-2013, 02:50 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Belt driven Dry Sump Pump which only had two scavenge sections bolted to the lug cast on the pan exterior between f/r scavenge points. Original oil pump still fitted as per normal to supply pressure side of system inlet for it was round hole in triangle shaped pad. Remember seeing pics of this in an early sixties mag about dry sumps-there were two setups, one had shelby links ,but cannot remember the other.
Jac Mac
