Old 10-07-2013, 01:51 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by vector1 View Post
Holley needs to check their calibrations, I've had 2 carbs with the primary screws 1/2-3/4 turn out, and the secondaries 2+ turns out, and know of someone else who had the same setup. Also, the last carb had the butterflies closed with no t slot showing.
BossHemi429, since you are an advertiser for the ultra hp, can you explain this?
I've had Ultra HP, QFT and many other new carbs.
Not one has had a "correct setting" for the idle mixture and speed screws out of the box.
Gary
