Old 10-08-2013, 01:13 PM
Voyager's Avatar
Voyager Voyager is offline
Cobra Make, Engine: SPF #2920 w/ Keith Craft 408
Jerry,
Regarding setting it up so the arms on the cross shaft on the fire wall point upwards instead of down – are you talking about the shaft under the clutch reservoir? I will try that.
Regarding the double spring setup to pull forward on the carb arm – are you saying attach the double spring on the front side of engine and have no spring attached to the other side?
Bob
