  #185 (permalink)
Old 10-09-2013, 07:34 AM
DanEC's Avatar
DanEC DanEC is offline
Thanks everyone. I'm going to check with the local radiator shop first on the expansion tank. It's only a pinhole right in the solder joint so I'm hoping it's an easy fix. But, if he says its an iffy thing then I'll get a new one. I took a chance buying it used but the forum member said he pressure tested it and thought it was good. You never know for sure.
Nick - have you had some of your tanks installed on an ERA with an FE? I know ERA has specific heigth dimensions in their manuals for use in swapping the tank around for a Cobra. Mine is right on their dimension and appears to have about 3/8 in clearance at best.
Dan
