  #186 (permalink)
Old 10-09-2013, 07:43 AM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Hi Dan,
I have the ERA tank and have test fit it. The issue with an FE is that it will rest against the distributor cap, unless you have the narrow diameter cap. I didn't want that so am using a standard cap on an MSD distributor. Doug at ERA indicated the tanks are pretty tough and can be "tweaked" with a pry bar enough to move it away from the distributor cap. Tweaking it a bit would make it look every so slightly crooked. Although I'm probably the only one who would every notice it, my preference was to use a spacer to move the entire tank out a bit. I took the easy way out since I don't have the proper tools for metal fabrication and ERA made a 3/8" spacer for me.
Let me know if photos would help - not sure what path you're taking with this.
Regards,
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
