Old 03-24-2002, 10:04 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb Some info on my cooling system
My West Coast cobra has a vertical radiator, it therefore will cool better than one set at an angle...having gotten past that, however, my car will have a 7 row heavy duty radiator, and the puller fan....only
This, according to Vern Redel, is plenty of cooling for my 514 SVO....if I need more, during desert heat, I will add Red Line Water Wetter, which will certainly drop the temp.
Pusher fans will disrupt the air flow, as stated in the earlier posts. Certainly try the water wetter before you spend any money and make any other mods.
Your next move should be an OIL cooler, IF you still experience overheating....set it in the lower front intake, below the radiator...I promise you your temps will drop !
Use 1/2 mininum internal hosing for the oil lines.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
