Old 10-10-2013, 09:24 AM
Karl Bebout's Avatar
Karl Bebout Karl Bebout is offline
I'm using Evans waterless coolant. Its expensive, even getting it off the internet. My cooling system holds 5 1/2 gallons and became even more expensive when a my 2"
to 1 3/4" adapter went south and almost three gallons went down the gutter. Make sure you get every bit of water out of the system before using it. I opened the water jacket fittings, removed the stat and hooked up my shop vac, in reverse, to the water inlet and let it blow for several hours over a few days. Doesn't make the engine run any cooler but now I don't worry about any steam pockets ruining stuff.
Karlos
