Old 10-11-2013, 01:37 PM
Mastiff107's Avatar
Mastiff107 Mastiff107 is offline
Cobra Make, Engine: '66 Shell Valley, Original "K" Code 289
If you have a "coolant based breakdown" you can always fill it back up with water. You loose the properties of the Evans but you can mix it with water in any ratio you want and then just drain it later and refill with Evans. For some reason folks seem to have the idea that you will be stuck and have to be towed back without backup Evans. There really is no down side to Evans. I've been using it in my '38 Chevy for years. One day soon I'll get up enough energy to completely drain the Cobra and use it.
