Old 03-24-2002, 07:44 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Any speed shop will have gaskets that fit Holley square bore. Holley, Fel Pro, Mr. Gasket, etc. They can be trimmed with exacto knife. If push comes to shove, get a roll of gasket material and make them. Can make spacers out of sheet aluminum stock also. Or get heat shield kit, use as a spacer, and cut off what you don't need. Just remember to use longer carb studs, and grease the mating surfaces so you get a good vacuum seal.
