I autocross with -2 camber front and rear, 0 toe front and 1/8 toe rear. You will wear tires fairly quick with this much camber. I also run these settings on the street. I also run max sway bar setting on the front and minimum on rear and reset when back on street. Tire pressure seems best from 28-30 psig for autocross. Tires are Nitto NT01s.
