Old 03-25-2002, 08:54 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
ronzara, I have used several of the Lokar shifters. I order them with the 6" handle which makes for a nice looking shifter. If you use the round boot it looks like a 4 or 5 speed shifter. The shifter mounts right behind the bellhousing on the C4 so generally it is too far forward. I normally mount it at the tailshaft bolts. The instructions they give with the shifter won't cover this but you can use the mounts they give with a little modification. Most other shifters mount to the floor which makes them taller than needed. Since this one mounts to the trans it gives a clean look.
Don
