Old 10-19-2013, 02:59 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by Bobcat View Post
Just curious , did you make a jig/fixture for the conversion ??
Not really. Since I was just going to weld them on straight, it didn't really need a jig. I just needed to be sure they would end up at the same distance.
Using simple threaded rod of the correct diameter, it was fairly easy to get them square and get the right distance.
After that, I mounted them up, and used plumb bobs to make sure they were exactly equal. As adjustments go, it was fairly tedious and time consuming. Mostly, I think, because I had to make it up as I went.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
