Old 10-19-2013, 11:15 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Ted--------if your heads have been milled to raise compression, it should actually take thinner gaskets fot the proper geometry to line up wth the ports and bolt holes---
Also, make sure the manifold isn't setting on the block end cross rails holding it up making it impossible to get a correct fitting--------
