Old 10-20-2013, 05:25 AM
mdross1's Avatar
mdross1 mdross1 is offline
In the end you should do a pressure test to be sure you are close to the required pressure to make the brakes work as advertised. We had to move the pivot point of the balance beam up higher on the pedal (running dual masters) to get the 1000+psi with comfortable pedal pressure. Once we reached the pressure Wilwood recommended the brakes are incredible.
