  #85 (permalink)
Old 10-21-2013, 03:48 PM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Looks great Kevin. I like the air cleaner and valve covers. Very original looking. Where did you find the breather equipped chrome pentroofs? I've seen posts where members were looking for them I believe. Very nice.
A lessons learned I forgot to pass on - it's a bit of a pain prepping the oil pan for the oil temp gage sender after engine installation. I had to go shopping for a bushing for mine as the hole in the pan was too large for the ERA equipped plug. It may depend on the oil pan source. I found the bushing easy enough at Pep Boys.
Dan
Hi Dan,
Thanks. Got the valve covers at Tony Branda's - 390-427-428 Valve Covers
They sell them with and without breather holes. I know original cars didn't have breathers on the valve covers but decided to go this route rather than tap into the Edelbrock intake. The builder also indicated having breathers on both valve covers (with no PCV) is a good set-up. Hope to find out first-hand soon.
Thanks for the tip on the oil temp sender. I did remove the plug and make sure the threads were clean before installing the engine but assumed the ERA sensor would screw right in. I'll check that out soon.
I appreciate the tips and things to watch out for since this is my first time through this...
Regards,
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
