Thanks Frank,
Actually the Master Cylinder seems fine (for now) The principal reason I was not just going to put a slave cylinder rebuild kit in was that the exposure the slave gets to road grime and contamination is pretty great. Also, this slave did not have a dust boot at the piston end and is likely pretty torn up inside.. That, along with the cost of a new slave cylinder being about $60 makes the decision easy.. BUT READ ON..
The reason I cannot find a Girling slave cylinder like mine is because the guy that built my car didn't use the Girling part at all (thank you Don) he used a replica.. lol.. ok, not really.. He likely, like me, couldn't get a Girling unit locally (before the internet) and used some Chevy unit, which explaines how a Girling slave cylinder has gone 20k miles just inches from the exhaust header of a 450 hp Ford FE... (thanks again Don.. I think)
So.. What to do.. The CNC unit is great.. It is only $60. The folks there are awesome on the phone. I think if I can get theirs to line up I will buy it.. The bore is stainless steel, it has a 1.125" push, it has an .875" bore (which will make the clutch easier to push by almost 20% over a .750" Girling, or any other similar unit and replacement parts are cheap, $20 for a slave kit (and being stainless you should be able to rebuild it several times.. but you probably will not need to)
OR.. I could send "Don" $120 and he will send me a replacement he calls "better" than the one I have. Hey it includes a new bracket.. I suspect a trip to Pep Boys may yield a direct replacement, if not I will build a billet aluminum bracket for my new CNC unit...
Thanks for all the good info. I suspect a year from now this will save some poor slob a ton of searching for a similar "Girling Slave Cylinder"
Regards,
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
