Thomas
Welcome to the forum. There is no wrong place to post stuff here!
Without trying to create another Pace-Fest (not that there's anything wrong with that), go down to see Carig at Absolute Pace. Check out the other threads here about Pace as well - there's plenty to see.
Regardless of whether you end up with a Pace Car (hmmmm), Craig is very knowledgable about all available build options and will genuinely steer you in the right direction. Pace's kit is as much of a kit as the FF option with all new components included. If you can change your
oil, you can build a Pace. FF does look considerably cheaper but with shipping, conversion to RHD and compliance it will probably be around the same total cost.
Good luck
Geof
