Originally Posted by mickmate
Hey Dan, you need to try a different method for getting in and out. I don't bend and pull my leg in after. I step across and in from a standing position and lower myself into the seat. Extrication is a reversal of install, get up, then out. What do I do with a top on you ask, I crawl across to the other side and reverse myself in.
Nick - what I really need is a removable steering wheel.
Right now I think I have the steering wheel too far back also, which interfers with your approach. I've left it alone for now until I get the rest of it figured out.
I have kind of practiced an entry form. I lean over and brace my right arm on the transmission tunnel and left and bend my right leg and drag it under the wheel and put it down as I swing my butt in and try to keep from literally falling the last few inches into the seat. Then I draw up my left leg and pull it in. The exit is not as well coordinated however. I may have to work towards your approach.
