Originally Posted by ERA Chas
I'd replace those 2" straps with 3" and put a clamp across the extinguisher so it doesn't become a projectile.
Hi Chas,
I was considering adding a submarine belt - upgrading to wider shoulder straps would be a good upgrade as well. And, you're right about the extinguisher bracket. I'll either weld a couple quick-release clamps on to replace the rubber bungies or, more likely, just get a vehicle-rated bracket. Want it black anyway...
As you can imagine, getting the car this close to finished is going to make for a long winter. These will be good winter projects, thanks for the suggestions.
Regards,
Kevin
