Old 11-07-2013, 03:11 PM
Default How did you hook up the volt gauge
Caldon How did you hook up the volt gauge? The 2 main wires should be contected to each other with a wire tail going to the voltage gauge. Light should snap right in new gauge. Ground wire needs to run directly to a ground on the car. Don't run it into any wiring behind dash. I think you hooked your ground into the sender curcuit to the gauge or have a loose wire on the back of the dash. It's back feeding. Simple to fix. Good luck Rick L.
