Old 11-18-2013, 11:28 AM
DanEC's Avatar
DanEC DanEC is offline
Default Toploader Transmission leak
Crickets chirping over in the Transmission Forum so I guess I will try here in All Cobra Talk.
My rebuilt toploader is seeping a few drops of lube at the main case to tailhousing gasket. I snugged up the bolts but still a drop now and then. I'm still putting the car together and don't have the transmission tunnel in so I have pretty good access. I would like to drain the transmission and pull the tailshaft housing back to either replace the gasket or put a ribbon of gasket sealer on the existing one.
Anything that prevents sliding the tailhousing back or off after the 4 bolts and yoke are removed?
Tanks
