Thanks to all for the excellent responses. Blas, no the fans are working fine. Actually I replaced the stock sensor with a 180 degree unit years ago when I was having overheating problems that turned out to be head gasket failure. The fans come on earlier and run longer than I would like, so I thought I would go back to the original value sensor. Also, regards my tach issue, I am not having much luck locating the ground wire location near my accessory plug under the dash. I sent you an email about it but hadn't heard back. I assumed you were busy with your trip.
