Neither the carb or the distributor are staying - it will be Webered. I avoid colored aluminum - just how I roll.
It provides a good starting baseline - it ran when it left Brents shop and I can count on him for any startup issues if needed. Pretty sure that dist won't work with the Webs.
The weight does not include the tube steel supports, but does include the stand. Lighter than I expected. I was going to run an alum mustang bell housing, but the front plate on the gear box does not match so I am going to run a QuickTime which will add a little back in.
On the QuickTime - Is it worth it to purchase SFI - does the bottom still need trimming on a QT.
Opinions or Real life appreciated.
x-chr
