  #221 (permalink)
Old 11-24-2013, 07:09 PM
patrickt patrickt is offline
Originally Posted by kevins2 View Post
Yes, that's the location. Also seeping a bit over toward the driver's side as well but not as much. Engine builder had me put my shop vac on one of the breather holes to create a vacuum in the engine and block off the other one. Cleaned up the oil with carb cleaner and tried it. Still leaks so will try it again. I'm using "Right Stuff" gasket maker. I think that's pretty much what the RTV is. Let me know if there's a difference and I'll try it.
Dan, sorry, I seem to have hijacked your thread...
Kevin
I know you think it's leaking oil, but it's really "misting oil." There's a difference. The Right Stuff is a great product. But for a little teensy weensy hairline or super small pin-hole back there you want something that will seep in to the gap and that you can "squish" in to the crevice with your finger. Give Ultra-Grey a try. You've got nothing to lose. And make sure it's not coming out from the valve cover gaskets and trailing back there and fooling you. Take a white dinner napkin and run it along the bottom of the valve covers, especially the back of the passenger side. If you see any oil stain from doing that then you have to deal with that first. What looks to be a small leak, using the dinner napkin test, can often times be the majority of the problem.
