  #82 (permalink)
Old 11-24-2013, 08:46 PM
Towmaster's Avatar
Towmaster Towmaster is offline
Ok so another bit of an update. I have got most of the bits I need to screw this thing together now and have taken a few pictures along the way.
This is with the manifold removed and showing the complicated AFM valley cover
Removing the rockers. I will be installing an upgraded trunion kit before I put these back in. They have a habit of dropping needle rollers in the oil pan..
All of the rockers removed. Check the different shaped rockers....
Showing the oil galleries to feed the AFM or DOD system.
This is the difference between the AFM and non AFM lifters.
Heads valley cover and water pump removed
Old timing gear and chain etc.
Sump and pump and some lines from the bottom.
I will break it up a bit.... not sure how much it can take....
