Next lot coming up....
New double row timing chain, new crank sprocket and cam in place.
New ARP rod bolts in place, also shows Reluctor wheel
I had to block off this hole with a piece of aluminium I turned down in the lathe. This is where the regular
oil pump feeds oiil into the engine. Mine is now fed in where the
oil filter would have originally been. I also made a 4mm aluminium plate to cover the hole, it is secured by the original
oil pump locating holes. Sorry forgot to get a photo.
A bit of clearancing required for double row chain. It's the bit near the sensor.....
Timing cover back in place.
Sat the heads and pipes on ....... mmmmmm
And last but not least I bought a heat exchanger from a guy called Gene Felton.... Wikipedia him...
And that's about it for now. Gotta put the heads back on and a bit more fabrication work to do to mount the thremo fans and the heat exchanger etc.
