Originally Posted by DanEC
If Keith Craft's shop is any indicator, there seems to be some argument in favor of being able to prevent some oil leaks by sealing the exterior of the gasket after assembly. On my motor they went completely around the oil pan (maybe other locations too - didn't notice) and applied a small ribbon of black RTV over the edge of the gasket.
You will regret that if / when you have to do lower maintenance or repair and remove the pan. It's a B!tch to cut through the outer RTV AND the RTV on the gasket surfaces. Keith probably does not want an engine to come back as a leaker and because they don't have to do pan removal like an owner might.
I've had my pan down 4 times over the years and have nearly perfected the art...
