  #227 (permalink)
Old 11-25-2013, 04:25 PM
ERA Chas ERA Chas is offline
Yeah, I guess it would add a lot of effort to separate them. That small, neat, untooled bead sure looks purty for now though. And so far no identifiable leaks although idling in the driveway is not much of a test.
A cool down after a 5500 RPM run will tell you if it's gonna stay dry. Most likely it will not leak, which is why Keith does that without a lot of other tedious work to ensure a tight seal with these types of pan rails.
You should re-snug the pan bolts after 100 miles or so; they will have backed-off a bit. Just don't crank on them.
Chas.
