Old 11-26-2013, 01:23 PM
letsboogie351's Avatar
letsboogie351 letsboogie351 is offline
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
Rog
my Painter has ABS on his Cobra and it works very well. Though initially there were problems. You must ensure that if you are using factory setup that the tyres you use have the same circumference. Otherwise the computer will have a problem with the different signals from the front and rear wheels. I think he also used the booster and m/cyl from later model Ford as well.
Although I don't think that is critical as I have also seen other cars use XF booster and m/c with their ABS setups
Doug
