Originally Posted by dhs.buckley
I have been looking at getting a little more Hp from my 302 which is about a 96 mustang block with edelbrock perfomer rpm heads and manifold with a 465 holley on it, i have been told the best way for cheap hp so far is to upgrade the fuel pump from the original 70 lph to a holley blue 110gph pump and use a 670 holley street avenger carb. any other thoughts on this combo?
If your fuel pressure, fuel supply and fuel ratio is all okay you dont need another pump. It won't make you any more HP.
