Help with cam selection
Looking for a bit of help here. I am building shell valley and have been buying up engine parts. Here is what I have at this point. I will not be stroking the engine. It is a 351w bored .030 to 357c.i. a new balanced rotating assembly. I have a new set of trick flow fast as cast 170cc heads with 61cc chambers.Compression ratio will be about 9.5:1. I currently have the edelbrock performer intake but am not opposed to getting the rpm intake if it would be worth the coin to change. I have an MSD distributor and 6al box for the ignition and I am figuring on a holley 670 street avenger carb. I also have a tko500 trans with the .68 5th gear. Looking for cam recommendations I will be going with link bar roller lifters. The car will mostly be street but might make a road course for play or a drag from time to time. I am willing to go a different route on the carb if needed but pretty set no the other parts I have. Is there a need to go with a custom grind for this set up? Thanks for your help
