You say a consistent 65 psi before the cooler, lose the cooler and any sharp 90 fittings going into it and see what happens. Keep the cooler installed for the cool effect and put caps on the inlet and outlet. You don't need a cooler unless you are going to race, and if you do race you will probably have to change it out, seems it could be the restriction along with any sharp 90's.
