Old 12-03-2013, 07:25 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Hal,
Excellent points. Out of all the coolers I have installed only a hand full of guys let me 'dummy' up the coolers. (Easy to install a Finish Line cooler and have it appear from top , bottom, back, as a functional cooler but the flow to the cooler has been blocked off.)
Perfect example of why you could use the sand which type thermostat. With this type no more lines would be involved other than the two original lens.
DV
