  #29 (permalink)
Old 12-03-2013, 09:51 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Ok......so its good pressure up to the cooler.....?........then it has to be a coooler remember too that every 90 degree turn in the oil line causes a loss in pressure.......I can't remember the numbers......
What cooler type are you using..?.....
Bypass the cooler up front at the cooler....just put a straight tube between the inlet and outlet hoses and see what happens then........
