Thread: engine idle
Old 12-07-2013, 01:42 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Set your idle and mixture settings on a HOT engine. This is the way it will idle HOT. Cold engines will not idle well until HOT. Keep you foot on the pedal at a higher rpm until HOT or just drive it away when it's warm until HOT.
Just having some meaningful fun but a carb with no choke will act like this.
As far a dieseling, bad fuel, not the right fuel, vacuum leak, wrong timing.
I usually set my idle at about 1000 rpms. Above 1200 rpms with a light spring in the dist. the advance starts to move so I stay below that.
My cam is in the high .500s with a 233/237 dur.
Lou
