Originally Posted by genolan
I'm purchasing a Backdraft cobra from Washington State and It's titled as follows
Year 1965 Make KitV Model Style Series Body Roadster
The engine block code is D4AE-8015-AA8 6A17.
Can I register it as QQ plates?
If not what is the process do I need a full blown safety inspection?
Should I just try and register it as a plane 1965 car?
This question is important before buying a car. Luckily you should be A OK in NJ with the 1965 registration.
You will not get QQ plates, do not try, it will only open you up for a problem that may require you to enter the full NJ process (which you do not want to get involved with). Simply walk in with your title and let them guide the way.
