Old 12-09-2013, 01:36 PM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Exclamation
Originally Posted by genolan View Post
I'm purchasing a Backdraft cobra from Washington State and It's titled as follows
Year 1965 Make KitV Model Style Series Body Roadster
The engine block code is D4AE-8015-AA8 6A17.
Can I register it as QQ plates?
If not what is the process do I need a full blown safety inspection?
Should I just try and register it as a plane 1965 car?
Was I not clear in explaining this to you in the past
The car is already titled? Then it gets a like and kind title in NJ
The make "KitV" is your only concern, and may get your cars paperwork pulled by the special titles division on State Street in Trenton. if that happens, then you must go through he "kit car" process in NJ, from scratch. Not impossible, just time consuming........
Can you get QQ plates, sorry, NO, and if you attempt to do so, you risk the forfeiture of your paperwork and your car. Enough said.
Register the car with regular plates, or send in for a set of custom plates, pass inspection to 1965 (or 1974 per the year of your engine block) standards, and be done with it.
Bill S.
