Beemer
If your vent hose is kinked it's an easy fix. These hoses are prone to kinks. Simply remove the right rear wheel, remove the inner fender and you'll see the vent tube going down the filler neck and into the tank. Go you your local parts store and buy about 3' of fuel line and replace it. Tie wrap it in place. SCOF has a tech article on it (if you are a member)
