Old 12-11-2013, 09:36 AM
vatdevil vatdevil is offline
Cobra Make, Engine: Superformance #522
Originally Posted by D-CEL View Post
Yes. But you have to run all three. If you run one solid bushing, it will take all the load.
My car has two aluminum front mounts and the housing bolts directly to the chassis. A side note, it does transmit considerably more noise into the chassis
JASON
Yes, I plan on installing front differential solid mounts also. Did you make a new rear bracket for the differential or modify the existing? Noise is fine, this wheel hop is not.
