If you are using the Large Black (heavy) Remote filter block (?) the internal holes in the large "NUT" may be partially blocked. There are much better designs.
I got rid of this, and cleaned up the line routing with an adapter like this in a size 10.
http://www.aviaid.com/shopsite_sc/st...oler-adptr.htm Bottom of page, no internal sharp corners or edges to reduce flow.
