Old 12-14-2013, 05:07 PM
UKjohnnycobra UKjohnnycobra is offline
Cobra Make, Engine: Euro 427, Ford 302
Default Do you have a burping problem?
Do you have a burping problem? I don't mean after drinking a case of fizzy American beer, i mean eliminating air pockets from your engine. I have used a simple mod which works for me, and might be of interest.
My Cobra is self built and has a familiar problem, that is, the radiator is lower than the engine. I had tried all the burping methods available on this forum and others and despite that I still experienced unpredictable temperature changes and sudden coolant losses, which I think were die to air pocket hotspots. I tried filling the engine block through the temperature sender port, but I could not get rid of all the air. I have drilled the thermostat. The design is such that I couldn't add an expansion tank into the top hose which I've seen on other Cobras.
So I added an expansion tank at the back of the engine bay at the highest point available. This provides a header in addition to expansion and has a standard Lever Lock pressure relief radiator cap. I fill the system from here. A hose from the tank goes to the overflow pipe on the radiator fill neck. The radiator is fitted with a non pressure relief cap (available from Summit) which allows free flow through the overflow pipe. I then fitted a standard ball valve (from a plumbers supply) to an unused tapped port on my Edelbrock Performer intake manifold. The port is next to the distributor (see photo).
I can fill the system from the header tank and vent the air through the ball valve. Or, by adding a barbed fitting to the ball valve, I can add coolant through the valve, (using a large funnel on a long tube to provide hydro pressure) and vent through the Lever Lock, in which case the air is forced through the radiator overflow into the header tank.
I have the overflow from the LeverLock connected to an overflow tank as initially I did not know how much coolant expansion and overflow would be involved. After many runs the system has never lost fluid and has never overheated.
Drive It Like Your Hair Is On Fire
