Your engine is immaculate wow!!!!!! Yes that is what I have. I have not removed it yet. Hit the bottle last night and need to recover
QUOTE=Rick Parker;1276095]If you are using the Large Black (heavy) Remote filter block (?) the internal holes in the large "NUT" may be partially blocked. There are much better designs.
I got rid of this, and cleaned up the line routing with an adapter like this in a size 10.
Remote Filter and Cooler Adapters at Aviaid Bottom of page, no internal sharp corners or edges to reduce flow.[/quote]
