Hi all,
My handbrake/ emergency brake is failing.
I tighten it up and it holds tension on the ratchet. It clicks up around half way and is tight working well.
Then I find after a few uses it releases tension and I can pull it straight back with no tension on the cables.
I am tightening up the bolt/nut under the brake but think there needs to he something to keep the bolt under tension/tight.
Any thoughts...
