Now Ned, think that over again. REVERSE rotation, not mounted. I've yet to see a Chris Craft Cabin Cruiser with a prop in the back, and one amidship. Unless you guys in Cali. do something different !
Originally Posted by Nedsel
Some boats used twin engines, and one would be mounted backwards.To determine if the engine you located is one of those, the distributor would be a good starting point, since it determines if all the internals rotate in the opposite direction from standard. Unless you plan to drive more in reverse than forward.
