  #27 (permalink)
Old 12-24-2013, 05:52 AM
madmaxx madmaxx is offline
You nailed it!!
"The other things to consider are camshaft choices flat tappet or roller, tight tolerances or loose.
Finally the engines efficiency, tight tolerance lighter viscosity loose tolerance higher viscosity"
Problem is 99% of the guys on this forum have no clue what tolerances their engines were built with and 50% probably don't know if they have flat tappet or roller.
Originally Posted by mdross1 View Post
This is always a hot topic in any forum.So many are certain they are running the correct viscosity oils because they might have been told it would or they truly believe if it works in this engine it has to work in mine.
No doubt they will get away with their choices but for their engines best protection especially at startup and in their unique climate (Northern cooler Southern warmer). The other things to consider are camshaft choices flat tappet or roller, tight tolerances or loose.
