I would suggest a 650 DP if manual and you want more power.
I have the same heads with RPM air gap and 35-771-8 running a 750 DP
The airflow through my heads with my cam calculated somewhere around 710cfm
I am making 451hp@6100 with this combination.
What you have should work well.
Check with Holley as they would need more info to help select properly.
