Whaler,
Happy to see you using RED loctite on the base screws. I lost a small block chevy years ago to a carb screw. Got past the valves and bounced around unitl it cracked the cylinder wall.
I too am using the exact set up.
I am going to use a 4-hole gasket between carb and turkey pan,
open square gasket between turkey pan and the intake.
