I don't have the springs here but the rear ones I had were raised and stiffer so the rear was really tail happy. I put in the ones you have on the car and it fixed a lot of the over steer problems. Check the King springs website, there are 6cyl versions that would have a softer ride but don't know about the handling. You really want to keep it reasonably stiff in the front and softer in the rear or you will have problems keeping the tail in line around corners. I will try and get some part numbers for you.
